Originally Posted by JTS197
I am not sure if this would make sense, but I went outside to see if I could tell if either one of the CVs was bad. I used my phone to record each side to see if the CVs would rotate when I applied power. If they rotated while I was applying power that should indicate that CV was bad correct?
Well, neither one moved. However, I did not notice that the front driveshaft was spinning when I accelerated. Could it be a bad front diff? If none of the wheels are getting power but I can clearly see the front diff spinning under acceleration, that would make me think the front diff is the problem?
Did you jack the front tires off the ground to test this?
2005 4R Sport 4WD
"The last of the V8s!" - Custom TIG'd SS Dual Exhaust - King 2.5" +2 LT. - ARB Front & Rear - 37's - Dana 60 -
Build Thread
1977 Celica Liftback - LFX Swap -
Build Thread
