Originally Posted by JTS197
That does help and it makes me really think it is the front diff that is bad. Given that when my 4Runner rolled off the trailer, and started to drive normally, the front diff may have spun enough to catch on the part of the ring that had teeth, to drive around. And then once it spun around and got to the bad part, the transfer case just sent all the power to the front (least resistance) and the front diff could not engage because the ring is jacked up.
That would explain why I see the front driveshaft spinning with no power to any wheels. And then why locking the center, I was able to move, because half of the power was sent to the rear.
Thanks for the help everyone. Hopefully the front diff is the issue. I am taking it back today.
You said you drove 70 miles on it correct? The R&P would be fine if you did that.
2005 4R Sport 4WD
"The last of the V8s!" - Custom TIG'd SS Dual Exhaust - King 2.5" +2 LT. - ARB Front & Rear - 37's - Dana 60 -
Build Thread
1977 Celica Liftback - LFX Swap -
Build Thread
