Originally Posted by VincentGsrq
1st thing I will try is to hand rotate the compressor, thanks.
The 8-Oclock position on the needle was approximate and since the compressor never came on there was no cycling at all, the high side never moved.
I have not added any oil at all nor used refrigerant that contained oil, I always thought you only add oil when you change the compressor, if you dont install one that is pre-oiled.
With the car off I will check at the relay if I can excite the magnetic clutch, if the compressor does rotate freely by hand.
Thanks again to all suggestions
In my opinion the high side should have moved. If you measure the static system pressure what do both gauges read? They should be the same when the compressor is not running and system is cold.
