Vibration when letting off the gas after lift...
So I know, 'Search' and all that, but I've been doing that for like 2hrs now and cannot find anything super helpful for my situation.
I have a 2001 2WD 4runner with 220,000mi on it and I replaced the old sagging springs and trashed rear shocks yesterday as well as replacing the rear endlinks with longer (From the front) options.
Part's wise : KYB Gas-A-Just Shocks, Moog 81041 springs and a 2.5inch spring spacer, and the longer endlinks.
So after doing all this everything seemed fine, but on my way into work this morning I noticed that when I'm at 20mph or over, when I let off the gas I get a weird vibration/noise. Nothing under acceleration, just when I let off the gas.
I saw a number of people saying to check u-joints, but I had those replaced last year and they still look good. The driveshaft has always been a bit of a wildcard as it IS the 2 piece (Sleeved with rubber insert) driveshaft that the 2wd's have. I also replaced the rear-diff fluid last year and while I know I have a small leak in drivers side rear axle, it hasn't been anything that I've really even noticed.
So, have I raised the truck too much? Is there a possible Pinion issue (I read that our vehicles use Cardan Joints, but I don't know if that's true for the 2WD)? What else should I look into at this point?
2001 4Runner 4x2 Sport Package
2009 VW GTI (To many things to list)
