Originally Posted by Bumbo
I was going to recommend checking connections / cleaning but looks like you already did that.
Have you load tested the battery? Perhaps it suffered some internal fault which is contributing to the issue. You could consider replacing it and see if that resolves the issue.
Do the alternator and resting charge voltages look ok?
The load tester at my work shop wasn't working so i didn't get a chance to do so.
Explain what you mean by a "resting charge voltage".
My battery voltage is 12.6ish after being charged. Truck running it doesn't jump up to 14v meaning its not charging. I've put a meter on the stud coming out of the alternator while it was running and got a reading of 12.5ish volts.
