3rd Gen Alignment Qs with aftermarket UCA and 33s
Hi guys,
I have a question about aligning our 3rd gens for optimal tire fitment (33s).
Here’s some history:
- I run a Wheeler’s Eibach lift, minimal 2” in front
- I have had Skinny pizza-cutter 33” BFG KM2 255/85/16 MT tires for over a year and they’ve never rubbed
Until...
- I recently installed BTF Fabrication Uniball UCAs—They did push the wheel backward quite a bit, into the rear of the inner fender (effectively shortening the wheelbase). I love these UCAS- the on-road feel is amazing.
I’ve gotten an alignment, and it drives as straight as an arrow—Here are specs:
Left Front: 0.0 Camber, 3.3 Caster, 0.12 Toe
Right Front: 0.3 Camber, 3.2 Caster, 0.09 Toe
.21 Total Toe, 0.01 Steer Ahead
The question is: What can I do to push the wheel more forward in the wheel well, away from the rear of the inner fender? The UCAs are not adjustable. Is there a way to effectively “move” the LBJ forward?
And, if I technically COULD move the wheel more centered in the wheel arch, wouldn’t that affect the rest of the alignment. Would it negate the purpose of aftermarket UCAs altogether?
Thanks!
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
