View Single Post
Old 02-18-2020, 02:15 PM
Originally Posted by anormalflame View Post
Okay so I've been studying the diagrams a bit. I've plugged back in the 1J connection.
I unplugged the 1F connection which controls the stereo, antenna, door switches. The new Dome fuse didn't blow. Now my personal lights work and my dome light will work in the Door position, but not the ON position.
Ok, that's good info. Now to track down what 1J and 1F have in common.
1J connector has:
1 - R-L, 10A GAUGE fuse power output (to alternator and other stuff)
2 - R, Headlight relay trigger signal (pulls to ground when switch is ON)
3 - L-W, Power in from HORN relay
4 - B, Power to horns from HORN relay
5 - empty
6 - G, Power from TAIL relay for integration relay and interior light power
7 - R-G, LH headlight low beam ground connection to headlight switch
8 - B-W, 7.5A IGN fuse power output
9 - R-G, RH headlight low beam ground connection to headlight switch
10- G-Y, Front RH turn signal power out
11- G-B, Front LH turn signal power out
12- L-Y, Power input from 15A DOME fuse to integration relay and other systems
13- empty
1F Connector has:
1 - B-W, Door switch inputs (front RH, rear RH)
2 - B-Y, 10A Gauge fuse output gauge cluster, etc
3 - R-G, low beam headlight ground through headlight switch
4 - R-G, signal to high beam indicator
5 - empty
6 - L-R, Power Relay output to power windows and sunroof
7 - G, tail light power output / interior illumination power output
8 - R, headlight relay trigger signal (pulls to ground with headlights on/flash)
9 - empty
10- empty
11- R, headlight relay trigger signal (pulls to ground with headlights on/flash)
12- L-Y, from DOME fuse to rear cargo light output, clock, ABS ECU, etc.
13- L-Y, from DOME fuse to cruise control ECU
Looks like the most likely culprits are the ABS ECU and the Cruise Control ECU at this point.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
