Originally Posted by brillo_76
Mostly though it dosent stop flashing or the airbag stay on if the system has a problem.
You can check those wires are making good connections but if the light goes out the system is self checking ok. :/
You only seen this once? I guess keep an eye on it and see how it behaves.
Light doesn't stop flashing. On 3 seconds off 2 seconds as long as power is on.
Connections all appear good. Did a second check. Anyone know where the wires run to the passenger airbag?
I removed and replaced 2 screws I use to keep my phone mount from bouncing. I'm wondering if I was lucky the first time I mounted but not so lucky when I adjusted the mounts screws yesterday. That is the only thing I can think of... see photo.i can't imagine wires run here...
