Originally Posted by Anand
I have my magnetic shorty antenna for the WeBoost mounted to a cross bar (and then I pop it "down" to live horizontally off of the inside of the side rail when I'm not expecting to need it)...
Are you talking about the short magnetic mount antenna included with the MXT275 (and I'd imagine the 115)? Or adding a NMO style mount should be fairly easy. I've never measured to see if the 3/8" NMO will fit through the circular part, but it could alternatively just enlarge one of them. If that's not your cup of tea any of the generic 90 degree or "fender" NMO mounts should work just fine.
If you wanted to get fancy with it you could look into something like a Diamond trunk lip mount (or SUPER fancy with their motorized one).
Thanks for the responses folks! Was planning on adding an NMO mount to use with the MXTA26 antenna.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
