Originally Posted by phattyduck
That's the same problem. The leak comes out inside the brake drum area and gets on the brake shoes. Unless you removed the brake shoes to check for oily build-up inside, you won't know if that is your problem or not.
Thanks Charlie my bad on terms. I am told the front axle boots are torn and leaking grease, would that be a cause of my issue? I could not verify this and relying on a shops inspection. I did not see any sign of grease thrown around.
I have pulled all 4 corners of wheels and no sign of any leaks or impingement to shoes or pads.
