Originally Posted by 97Cruiser40th
Thanks Charlie my bad on terms. I am told the front axle boots are torn and leaking grease, would that be a cause of my issue? I could not verify this and relying on a shops inspection. I did not see any sign of grease thrown around.
I have pulled all 4 corners of wheels and no sign of any leaks or impingement to shoes or pads.
Yes, that could be the cause of your issue. Especially if it's been torn for a while, dried up, and had debris in the CV.
Also, a leaking axle is visible without having to put forth any work. Just look at the inside of your rear tires. You'll see the fluid running down the tire.
Mike
