Originally Posted by MStudt
OK, then a bad seal isn't the issue.
I ran a CV bone dry for about 3k miles with only noise, and sometimes the noisy you described. You'll get to a point where the CV will start to bind, and that could be what you're hearing. Something else to consider would be a ball joint. They'll pop once the grease is gone, and usually in situations like what you described as well.
Mike
Thanks
Took truck this AM and the sound was very loud and sounds clearly seems and felt like coming from rear but again only happened when shift into drive did not do it in reverse.
LBJ's brand new in November. It still perplexes me the experience only happens in drive i would think it would happen in reverse too
