Originally Posted by Iffykid
Would there be any possible gain by using PBlaster inside of the frame rather than WD40?
I believe Mn would be considered rust belt and with recent purchase of a 00 with what I would consider minimal rust considering it is from Mn I am looking at doing Woolwax or FF come spring when I can do a wash and dry on the frame before applying.
Anything is better the nothing. PB blaster is an oil. I mostly use FF in the frame. Some use WD-40. As well as all other types of oils out there. Transmission fluid is another commonly use undercoat as well
The penetrating oils my react with rubbers and seals. So make sure you stay inside the frame with PB.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
