Originally Posted by UnJeep
I use it and use pids for trans temp. It's been a while since I set it up. What is the exact "formula" you are trying? I'll set it up on mine to see if I get a reading. Maybe its not working because the tank sensors are shot?
Sent from my SM-N950U using Tapatalk
The "formula" that was produced by the Prius crowd as
4RunnerAquasport
had mentioned was A*500 / 3785 which i believe seems maybe a bit too simple? Ive been using the Vehicle Info Fuel remaining display and it works alright but every time i fuel up i have to go back and reset the % to 100, idk why my fuel sensors would be shot, my range reads "correct in the HVAC screen, but my needle will only go half way every single time
