oil is 100% personal preference. I see the value of synthetic, others obviously don't.
Your leaks aren't going to go away by switching to synthetic, they May get worse but I doubt it if they actually are valve cover related. Fix the leaks, switch your oil (if you're so inclined), nothing bad will happen. If you find something about the new oil you don't like, drain it and try something different. It's not like running oil for a change cycle is going to be irreversible.
