View Single Post
Old 02-21-2020, 02:40 PM
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
Front and Rear Differential OEM "DIY" Master-Rebuild Part Numbers
Front and Rear Differential Rebuild Information:
Part Numbers and Cost:
  • Front Pinion Bearing - Toyota (90366-30067) Front Outer $46.73
  • Rear Pinion Bearing - Toyota (90366-35087) Rear Inner $68.23
  • Side Bearings - Toyota (90366-50007) Case Side (Small) $43.26
  • Side Bearings - Toyota (90366-75001) Case Side (Big) $27.42
  • Pinion Seal - Toyota (90311-38047) $6.76
  • Toyota Transfer Indicator Switch: Beck and Arnley 201-1788 $11.51
  • (TTIS: ROCK AUTO PART NUMBER AND FOR E-LOCKER ONLY)
Total Rear Differential Cost: $203.91
Part Numbers for Front Differential:
  • Side Bearings - Toyota (90368-50006) $38.81 x 2 = $77.62
  • Pinion Bearing Inner - Toyota (90366-35023-77) $68.63
  • Pinion Spacer - Toyota (41231-22010) $12.95
  • Pinion Seal - Toyota (90311-38066) $9.81
  • Pinion Bearing Outer - Toyota (90366-30078-77) $32.77
  • Output Shaft Seal Left - Toyota (90311-47027) $13.24
  • Output Shaft Seal Right - Toyota (90311-47013) $14.40
  • Output Shaft Bearing - Toyota (90903-63008) $39.01
Total Front Differential Rebuild Cost: $268.43
If anyone can contribute to this in any way, that would be great! This is a complete guide to getting differential bearings for a lot cheaper than any of these other gear and bearing brands sell the kits at. In addition to this, the seals are from Toyota, which is a big deal for me. Also, this actually includes an output shaft bearing for the front differential which I have personally not seen in any "master rebuild" differential kit offered online.
This research results from a week long search into the best "master rebuild kit" online. What I finally figured out, the best option is to build your own master rebuild kit, and order from an online parts store. Personally, I always order from Conicelli Toyota Parts online parts store so these prices could be higher or lower depending on if you shop at a place like Camelback Toyota for instance. (I believe Conicelli and Camelback are the same with pricing.)
Feel free to add any additional differential, front end, or rear end drive-line component part numbers in this thread.
I WOULD LIKE TO NOTE: The rear differential breakdown is for an E-Locker 4Runner / Tacoma 8" 3rd member. If you do not have an E - Locker everything is the EXACT SAME besides the carrier bearings. You would order two of the "(small)" bearings. Not one (small) and one (big).
VernySanders is offline   Reply With QuoteReply With Quote
