Originally Posted by jeffsGT7
Thanks- I will look for it!
So is this the ambient temp sensor (under the hood)?
or is there an interior temp sensor?
It's the "Cabin" air temperature sensor, it's located behind the dash panel below the ignition switch, look for the little slotted holes, the holes and or sensor can get clogged or covered in dust causing it to malfunction, if so cleaning the dust should solve any issue with the sensor if it has a issue or as mentioned it may have a loose connection.
