I feel if the job was done right, using a torque wrench to tighten the bolts evenly and in sequence per fsm, bolts should not back out.
I think what happens is the vcg and that rubber under the vc bolt washers break down and shrink over time. Heat, cold and oil breaks them down. You could get away and just tighten the bolts down. However dont do it too long over time as you can bottom out, and snap the bolts in the head.
