View Single Post
Old 02-23-2020, 01:52 AM
keeperofgoal keeperofgoal is offline
keeperofgoal is on a distinguished road
Help with transfer case issue-removed rear driveshaft, in 4hi truck is stuck
Hello!
I have a 1999 limited took the rear driveshaft out to find a vibration (ended up replacing it with a used one problem solved) but while I was doing my diagnosis and I had it in 4hi and with the rear driveshaft out It was basically neutral in all gears wouldn't go anywhere almost rolled out of the garage on me in park. a few weeks ago I almost had the rear passenger wheel come off on me cause I didn't torque the nuts properly it was bangin around pretty good caught it in time though! anyways ever since then going into 4hi is a struggle like it only clicks in over bumps or under braking. also coming out of 4lo in finicky the thing blinks at me a lot. before the wheel incident it engaged and disengaged perfectly so I probably messed up something in the transfer case? Differential? I am pretty new to doing my own repairs so hopefully someone can direct me as to what to check. do I need a new transfer case? is it possible to have one wheel that is stuck in 4lo all the time? the other day my left e brake seized and I thought 100% I needed a new transmission the shaking was so bad so you just never know with vehicles! thanks in advance for any help!
keeperofgoal is offline   Reply With QuoteReply With Quote
