View Single Post
Old 02-23-2020, 12:29 PM
El Dusty's Avatar
El Dusty El Dusty is offline
El Dusty has a spectacular aura about El Dusty has a spectacular aura about El Dusty has a spectacular aura about
El Dusty's Avatar
Originally Posted by Gingahrunnah View Post
I’m curious how you altered the t-nut... I have this for my ski rack but ended up going with the clamp setup because the t-nut wouldn’t fit in the slots. I’m using the Victory 4x4 rack.
The clamp system took me a while to install and the t-slot system is not only lower profile, but much easier to set up IMO.
Did you also have to alter the spacers? Mine have tabs that look wider than opening on the rack.
That is correct. I trimmed the rectangular spacer tabs off completely.
My kit came with t-bolts not t-nuts and did need modification. If you hold up the t-bolt head to the profile of your slot you can get an idea of the material that needs to be removed. I trimmed mine with an angle grinder/cutoff wheel. Grind, test fit and repeat until you have a good fit.
It’s a bit of extra work to fit it just right but the connection to the rack is stout. I never have been a fan of the strap on connections and I really don’t think they are intended for the wide rectangular shape of these racks.
El Dusty is offline   Reply With QuoteReply With Quote
