Originally Posted by jross20
I grounded the SGI-5 to the frame vs the ABS harness... Was this perhaps a mistake?
Other random electrical things that I've had before this install are:
- Door lock button rarely works, fob works.
- Light around key cylinder now rarely works
- I always get shocked lightly when I exit the truck now. Like static but it's very apparent and always happens.
Any relation? Ideas?
I have the SGI-5 too. I get the little blips on the speedo - in my case, only when going up or down through 55mph. I have a feeling it is the SGI-5, not any of the wiring.
So, I'd say your other issues are unrelated.
- Door locks - check if the passenger door button works. You may have bad wiring in the driver'd door harness.
- Key cylinder light - that's a odd one - but the only light in the truck controlled by the integration relay (either bad bulb, wiring, or flaky integration relay)
- Its winter, and might just be dry where you are. Before you start getting out of your seat, touch and keep your hand on the door latch loop on the b-pillar as you get out. You'll never get shocked that way. If you can stand the smell, rubbing a dryer sheet on the seat cloth will work too.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
