Real Name: Ron
Real Name: Ron
Originally Posted by Kutanks
Car has 207,000 and seems to run good but white smoke when i started it up. Guy said it was normal that it did that in the cold (it was 15 degrees out when i went to look at the car)
At 15 degrees almost any car will have white condensed water vapor coming out the tailpipe immediately after starting. The major products of combustion are CO2 and H2O, so when the tailpipe is cold some of the water vapor will condense before exiting.
If the white smoke seems excessive, or continues when the weather is warm, then it's a problem. As it is, it's inconclusive.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
