Originally Posted by Jetboy
I know nothing about your specific situation. Generally if it's not a bad belt - a flapping belt is a result of a belt being too long, tension spring not being strong enough, or the pulleys being out of alignment. A pulley with a machining error could cause an issue if it's eccentric on the axis it rotates on.
I'd check your supercharger shaft for any play in the bearings of the shaft that the pulley is attached to as well. And make sure the pulleys appear to be aligned visually.
Thanks! They did say the original bet was too long. However, they did replace the belt. They said the new one was within their spec BUT it still has flutter.
