View Single Post
Old 02-27-2020, 06:56 PM
TotalAutomotiveLV TotalAutomotiveLV is offline
TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about
New ARB Fridge | ZERO Fridge Freezer
Who says you can’t have your cake and eat it too?
Be the envy of the campsite with a new ARB Zero Dual-Zone Fridge Freezer,
serving drinks AND ice cream at the same time!
Whether you’re a weekend warrior or long-term remote traveller, ARB has
the perfect solution to keep your food, drinks, and frozen goods sorted.
Zero Fridge Freezer Range Features & Benefits
• Dual, independently-controlled cooling zones (dual-zone models only)
• Each zone can be set to fridge, freeze, or off
• Removable compartment divider and internal lid (73QT dual-zone only)
• Integrated wireless monitoring & control via compatible Bluetooth-enabled devices (LINX,
Android, & IOS)
• Boost function for rapid cool-down
• Anti-condensation technology
• Highly-efficient, variable-speed compressor
• Convenient USB 5V, 3000mA outlet for charging mobile devices (fridge must be connected to
DC or AC power source for charging)
• Dual-DC power inlet at opposing ends for customized installations
• Front-AC power inlet for quick home or powered-site connection
• Tough, durable, steel outer casing
• Full height corner mouldings for added protection
• Recessed carry handles with integrated tie-down points
• Quick-release, front-opening lid with non-slip glass/bottle provision (47QT only)
• Quick-release, reversible, side-opening lid/s with non-slip glass/bottle provision (63QT, 73QT
& 101QT)
• Easy-view LED display
• Low power draw LED interior light/s
• Versatile, removable internal basket system with provision for tall items/bottles
Specifications
Capacity – Zero 47QT
47QT Single Zone: 65 x 375ml cans
Cooling Capacity: -8°F to +50°F
Weight: 47.6lbs
External Dimensions (in); (L) 26.6 (W) 16.7 (H) 19.5
Internal Dimensions;
Upper Compartment (in); (L) 19 (W) 11.5 (H) 8
Lower Compartment (in); (L) 12.4 (W) 11.5 (H) 7.1
Power Voltage: 12/24V DC / 100-240V AC
Integrated-Battery Protection System Consumption 0.8Ah*
* DC12V set at 41°F, 89.6°F ambient temperature
Capacity – Zero 63QT
63QT Single Zone: 96 x 375ml cans
Weight: 54.2lbs
External Dimensions (in); (L)29.7 (W) 18.5 (H) 19.5
Internal Dimensions
Upper Compartment (in); (L) 22.8 (W) 12.8 (H) 7.8
Lower Compartment (in); (L) 15.8 (W) 12.8 (H) 7.1
Consumption: 0.8Ah*
Capacity – Zero 73QT DZ
73QT Dual-Zone (25QT/48QT)
87 x 375ml cans with divider, 108 without
Weight: 62.4lbs
External Dimensions (in); (L) 29.7 (W) 18.5 (H) 22.2
Internal Dimensions
Front Zone - Upper Compartment (in); (L) 15 (W) 12.8 (H) 10.4
Front Zone - Lower Compartment (in); (L) 8 (W) 12.8 (H) 7.1
Rear Zone (in); (L) 6.7 (W) 12.8 (H) 17.5
Integrated Battery Protection System
Consumption: 2.9Ah*
* DC12V set at 5°F zone 1, 37.4°F zone 2, 89.6°F ambient temperature
Capacity – Zero 101QT DZ
101QT Dual Zone (43QT/58QT): 144 x 375ml cans
Weight: 72.5lbs
External Dimensions (in); (L) 36.8 (W) 21.5 (H) 20
Internal Dimensions
Front Zone - Upper Compartment (in); (L) 13.9 (W) 15.9 (H) 8.2
Front Zone - Lower Compartment (in); (L) 6.9 (W) 15.9 (H) 7.1
Rear Zone (in); (L) 13.9 (W) 15.9 (H) 15.3
Consumption: 3.1Ah*
* 12VDC set 5°F zone 1, 37.4°F zone 2, 89.6°F ambient temperature
For more details - Click Here
TotalAutomotiveLV is offline   Reply With QuoteReply With Quote
