Investigated the water drip in the Tundra, ended up pulling the headliner yesterday and pouring water over the roof. There is a surprising amount of condensation collecting above the headliner. I think it rained the night before.
Sound deadening material is hanging down:
These must have been unpainted brackets. The condensation and humidity above the headliner got to them.
Before:
I discovered water leaked in the top windshield seam. I taped the paint just under the trim, and laid a bead of sealant in the gap under the trim. Its a cheap aftermarket windshield so somebody must have screwed up the install and didn't use enough sealant around the top of the windshield. We'll see if my fix works and if not, getting the windshield reinstalled is probably the next step. The plastic trim isn't a seal itself it gets glued in with the windshield, I'm just adding more glue basically.
2005 4R Sport 4WD
"The last of the V8s!" - Custom TIG'd SS Dual Exhaust - King 2.5" +2 LT. - ARB Front & Rear - 37's - Dana 60 -
Build Thread
1977 Celica Liftback - LFX Swap -
Build Thread
