View Single Post
Old 03-02-2020, 11:48 AM
onepremiere's Avatar
onepremiere onepremiere is offline
onepremiere is on a distinguished road
Originally Posted by RusPro17 View Post
I was working on getting prices myself from Rago fabr. For mounts and cross bar to remove my front bumper and was planning on putting LP6’s behind my front grille. This was my only option I was finding with that safety sense. That set up looks pretty good. Looks like I will be holding off till I see what these cost. So you will not have to remove the front bumper?
Correct, do not need to remove the bumper. Install takes about 30 minutes.
Originally Posted by honda250xtitan View Post
I dig it! very similar to the "defiant" light bar mount i ran on my titan years ago. Guessing it runs in and bolts to the frame horns? If so, super solid.
Funny you mention that, I ran a Defiant bar on my Taco many moons ago, similar, however I am not using the frame horns. Using the top of the crash bar. I will share more on this later.
Originally Posted by 3rdgendreamin View Post
Would this work on a pre-facelift 5th gen?
Haven't had a chance to test this. I will be in touch.
Originally Posted by RedRunner_87 View Post
Definitely interested depending on pricing. Looks really good!
Thank you!
The only thing I see it looks like your can move the lights out further since there is adjustments to where you want the lights mounted. I already bought raptor lights I did not add yet. I was waiting till I added these cause of removing the front bumper. Also it will depend on the cost of this bracket. Maybe you can do install pics how you ran the lighting into the cab and hooking the wires up. I have been doing all my research on which wires I need from bajadesigns. Running these wires with the correct switch inside the cab you also need the correct volt push button for them. Just a little info if anyone else is looking to do on the newer 4runners.
There will be a fully detailed, illustrated install guide shortly. (Taking photos this weekend). As for my wiring Lol, it's very elaborate. I have a SwitchPros panel, the distribution block is mounted inside a waterproof housing (I know this is waterproof regardless) so when you pop the hood, it just looks like another fuse box. All my wiring runs to that. It is mounted behind my air box. Previous 4Runner I had is mounted behind the existing fuse box. Since the addition of safety sense that area is occupied by a new fuse box from the factory.
Originally Posted by Snyder View Post
Awesome looking product! You know approx. how much weight this holds?
Lookin forward to hearing more news!
-Snyder
Well I weigh 185lbs and I was standing on it. The brackets that go through the grille are .375 Hot Rolled Carbon Steel, the mounting points behind the grille are .188 Hot Rolled Carbon Steel. Massive overkill. It's tied to the bracket behind the grille with 8 1/4-20 flange bolts.
Originally Posted by tylertenny View Post
I think this looks great! Could it be mounted on the bottom part of the grille for those of us that don't have the safety sense box?
Originally Posted by Eric m View Post
THIS.... I would also like to not cover my beautiful heritage grill!!!
This! Is a great I idea. I will see if this could work! Wouldn't be hard, I just need to add additional mounting points to my brackets.
Originally Posted by Grug556 View Post
Interesting. Can you flip the bar so the lights can be mounted under it as opposed to on top?
For powder coating may I suggest you ask for something along the lines of a
Polyester TGIC Super Durable or a Polyurethane Super Durable. If you can get either of these that are also Anti Graffiti type coatings I would recommend. Lastly perhaps a fine sand texture in the above may be the most aesthetically appealing.
Strongly suggest no river or peel type textures even if they are SDs.
Need any powder help message me.
Wow, really appreciate the powder-coating info. I will definitely be in touch. As for the flip, yes you can flip it in theory. Need to try and see how it turns out.
Originally Posted by HanginInUtah View Post
I like the look. I think it will look really good with that style light, but I'm not sure about a bar light.
Easy way to fix that problem... now i need round spots!
Spots are classic look, IMO. I have a secret obsession with all the 4WD's in Australia, a lot of them run a similar set up.
Any update?
Hope we see a update soon from one premier. There is probably more companies working on a work around for the safety sense for the lighting.
Originally Posted by TheJokingExplorer View Post
Very interested. Can it be mounted lower?
This was mentioned earlier, going to see if I can work it into the design and see if it will work with the safety-sense.
Originally Posted by Baja Designs View Post
Very clean setup!
Thank you!
In Progress 2020 Pro
SOLD:Tactical Urban Grocery Getter
Instagram
onepremiere is offline   Reply With QuoteReply With Quote
