Originally Posted by DenverTiger504
I have been running the same size in SL for the past 3 weeks. Started at 38 and worked my way down to 32. 32 cold has been perfect on the road and driving around town at stock weight. I will probably bump it up to 35 on road trips with a loaded rig.
Just wanted to report back on the 265/70/17 SLs. 32 PSI set cold around high 30s/low 40s outside has been overall great for a empty stock weight rig on street roads. It’s subjective, but I think it’s smoother than the LT KO2 by a good bit. I occasionally do get a little vibration before they warm on the highway commute - not sure if psi related or balancing. I haven’t felt the need to mess with the psi as I did before at higher psi’s. I do think every rig is different and the moment I have more weight in or on the truck I will need to adjust.
