Originally Posted by Direwolf82
I would double check to make sure your gearing in the new diff matches your front gear ratio. If it doesn't it's going to be a little tougher on the drivetrain than needed.
And if it were me I would measure the living crap out of the suspension mounts, spring perches, driveshaft connection and all that fun stuff before I pulled it apart just to know if I'm looking at an hour or two of stuffing in a new diff and then however long to hook it all up versus having to cut all the existing mounts off the diff and welding in the mounts from the old diff or whatever might need to happen. It takes me a couple hours of plasma cutting and grinding to prep a diff for a full custom install.
Good luck! I like the sound of the project, wish you the best with it.
I believe 5th gens were only offered in 3.73. And almost alllll 4th gens are 3.73 but I have heard of some that are 3.91
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs |
5th Gen Brakes | Everything else is in the
Build Thread
