Originally Posted by Sauss
I wanted to bump this thread to ask a question. I just bought the 6112/5160 setup. I’m going between the 1.2” and 1.6” setting for the front. If I do the 1.6” setting, will I need the B12 1” coil springs to keep the slight forward rake? I have a 2018 SR5 4wd non KDSS. If anyone has a done this setup or have another rear spring idea to get the 1.6” lift in the front do you mind sharing some pictures? Thanks in advance. I’m also planning on KO2 tires but torn between 265 vs 275.
I did the 2" setting (6/4 for non-kdss), and used the Eibach 1" in the rear. Sits pretty level with 275 ko2.
