View Single Post
Old 03-07-2020, 10:01 AM
Pj Benn Pj Benn is offline
Pj Benn is on a distinguished road
Pj Benn's Hawaiian time maintenance and build
Howsit. New 4runner owner from the west side of Oahu. Bought my 1998 Limited 4x4 on new years day. It had 152k miles on the clock. Have been trying to get through all the maintenance and hopefully some upgrades in the future.
previous owner replaced radiator. Also has recently replaced starter, bilstein 5100's, ome 906 rears, front o2 sensor, air filter.
Since I've owned it I replaced the
-oil
-front diff oil
-transfer case oil
-rear diff oil
-rear axle seals
-2 new tires (fronts were cupped bad from unbalance and alignment)
-front brakes
-spark plugs and wires
also added a remote to factory alarm system and replaced the piezo.
Upcoming work
-cv axles (previous owner said binside boots split 3 years ago after lift) *done
-lower ball joints *done
-valve cover gaskets *done
-e locker sensor *wasn’t sensor. Replaced with used elocker
-rear driveshaft check balance/lube
-inner/outer tie rods(?) * done along with new rack
-sway bar bushings
-rear lower control arm bushings
Pj Benn is offline   Reply With QuoteReply With Quote
