Real Name: Skip
Real Name: Skip
You say it will start briefly and then die, one thing you can try to see if indeed it's fuel related is to have someone try and start it while you spray little short bursts of ether/starting fluid into the intake, just don't over do the ether, if it continues to run briefly from the short sprays of ether then you have narrowed it down to a fuel issue.
If it still remains the same, then the issue is weak spark, bad compression and or timing.
2004 Limited V8
