Originally Posted by OYOTA TRD
Does not work with the sliding deck. The other issue I did not like is that it makes it harder to open the jack compartment due to covering the panel latches.
To clarify the mount will fit, but a power tank will not. Could use the mount for something else.
It is a quality built product though and super easy to install, even with molle panels.
so to clarify, 100% will not work with sliding deck. in terms of the jack, you just need to unscrew the top nut (which has a handle) and pull back the mount to access the jack. we designed it that way to make it accessible.
