Real Name: Mark
Real Name: Mark
What Eibach springs did you go with? What tires and load did you go with? One of those is probably your issue.
The Boosters are the easiest thing to do. "Easy" isn't usually the way you want to go if you plan on keeping your ride. If you were doing something to sale i would consider. If it were me, fix what you have and do it right. Yes that will mean take the front back apart. Call who you had align and tell them what you thinking about doing, they may realign for free.
I have OME 885 and 5100's set at 0 and its a good solid setup. Again wondering what Eibach's you have. You could try moving the 5100's up to .85, that should stiffen a little. You will have to take the front apart to do that.
'04 Sport V8
OME 885's, 1/4" spacers - 5100's at 0 - Toytec Superflexes with 1" rear spacers - 285/70/17 - SCS Gunmetal SR8's - LR UCA's - 20% front - 6000k low's and fogs - LED'd everything- Blacked out head lights - JL Sub and Amp
06 White Tundra - OME 888's and OME Shocks - JBA UCA's - AAL's - Summit Dakar's Black - NRG 285/75/17 - 20% front - LED everything.
