Originally Posted by evan1242
So wire number 2 on the switch that came with the harness needs to go to the blue wire on your new switch.
Then just ground the new switch
Then just wire the 2 left over wires from the new switch to switched ignition power.
awesome. thanks! could I run the 2 together into a fuse line for the fuse box using a fuse tap? or should I find a better source?
J.
