Never tried a scan tool to cycle the valves in the ABS pump. I just drive down a gravel road and lock up the binders several times so the ABS pump cycles lots. Then immediately go bleed the brakes again moving lots of fluid through.
If still not happy, rinse and repeat.
You may have a bad vacuum line, or ………
Did you bench blead the new master cylinder before install?
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
