Originally Posted by dudes4runner
Ok. All of the sudden my air bag light came on. I've checked everything I could and have found nothing. I don't have an obd tool, so that's out. Any ideas?
what year is your truck there are 2 different flavors of air bag setups.
96-98 have a distinct set of parts
99-02 have a different similar set of parts but include front sensors.
This is the steering wheel portion of that setup.
SWITCH & RELAY & COMPUTER | 4RUNNER VZN185L-GKPGKA RZN18#,VZN18# | JT3HN86RXW0173191 | Toyota | Genuine Parts Catalogs | PartSouq Auto Parts Around the World
the steering wheel has a spiral cable, it will only go around so many times before it gets screwed up so if you somehow had your steering rack disconnected and your steering wheel spun around a bunch of times #bad.
here is the sensor portion of the setup.
AIR BAG | 4RUNNER VZN185L-GKPZKA RZN18#,VZN18# | JT3HN87RXY0283787 | Toyota | Genuine Parts Catalogs | PartSouq Auto Parts Around the World
does your cruse control work? if it does then the spiral cable portion of the setup is probably ok.
the only other portion is the sensor assebly up under the center bezel. maybe something got unplugged?
