Originally Posted by UnderFire
If your truck is crusty, or has high mileage, it will be super easy to run into hurdles along the way though, siezed alignment cams are $30 a piece and a wait or spendy from the dealerships, broken sway bar links, clapped outer tie rod ends, bad lower strut bushings, etc. All real possibilities that will 100% put you past the amount of time and money it sounds like you want to spend.
Sent from my JSN-L23 using Tapatalk
Truck is fine....it did 200k in Arizona and I put another 90k on the clock in California so fortunately there is not a single spot of rust on the whole truck.
