Originally Posted by Dieselchessy
Replace the valve cover gaskets, intake gaskets, knock sensors and harness, PCV valve, clean the IAC and throttle body, plugs and wires, the 2 coolant lines to the AIC, the vacuum lines to the intake(injectors), the fuel pressure regulator and its gasket, all the injectors should be cleaned and tuned, and all the injector O-rings and rubber bushings should be replaced.
That should just about cover it...….
Luckily I did all that when I swapped engines
. I just didn't remove the intake manifold due to having to replace more gaskets.
