Originally Posted by tvpierce
This tells you it's something with the axle, not the housing.
Pull both axles out and stand them up side by side on your bench, and carefully compare them. I still think you have something out of place on the offending axle: a bearing, retainer, or ABS tone ring that's out of position.
As others have said, if the spines were damaged, you could see that from across the room.
and then take back to the shop...both of them...and say...see how it is supposed to be ?
