Originally Posted by phattyduck
In theory, yes - but good luck getting it right if you aren't on an alignment machine or measuring with good tools.
Oh, and you want the steering rack centered in its available travel (so L/R tie rod adjustments are similar) for multiple reasons. If the rack is off center, you can have mis-matched turning radius and bump steer while travelling straight.
It's very small adjustments as long as the wheel isn't way off, like say 90* or something extreme. Then I wouldn't advise it and instead take it to a shop.
When I adjusted the 10 degrees or so my steering wheel was off this way, it was very simple. I marked with a pen the starting position of the OTRE, loosened the nut, rotated each side about 3/4 of one turn (one side clockwise, the other counter-clockwise since it's mirrored on the rack), then tightened. Worked perfectly and didn't affect my alignment at all that I had just had done a few months prior.
Attached is the page for the FSM if it helps for future searching & other members.
