Originally Posted by HiluxSurf SSR-G
is that self-adjusting? meaning when you have cargo in the back, it will increase the brake pressure in the rear brakes? and when there's no cargo, the rear brake pressure is reduced
No, it's not self-adjusting. I added a Wilwood proportioning valve at the master cylinder. You set it using a dial and once it's set at a value, it stays there. So the brakes will not self adjust for cargo load.
Originally Posted by Ed_C
Ahh forgot those calipers have integrated parking brakes.
As Bad Luck said, it's only using the rotor from a 4th Gen. No brake shoes inside the rotor or anything like that. The parking brake on the Mustang caliper is cable actuated.
