SOLD 2000 toyota 4runner 4x4 Imperial Jade North Hollywood,California $5000 OBO
Hello up for Sale is my 2000 Toyota 4runner V6 Limited 4x4 Imperial Jade with 254,XXX miles.
Vehicle has a mild 2” Bilstein lift on Ko2 Tires. Vehicle has some upgrades that I have done. All upgrades have less than 1000 miles on them. Since I’ve owned the vehicle I have driven less than 1000 miles(I’ve owned the vehicle for 2 years). I was trying to make an off road vehicle that was very capable that I can take camping with me. Unfortunately the past two years have been busy for me; I haven’t gone camping therefore I haven’t really used it. The vehicle has a clean title with NO Check Engine Light on. I just paid for the tags and smog was done as well. I have pink slip and smog certificate on hand. It’s time to move on; my loss is your gain. I’m asking for $5,000 O.B.O. Cash Only. I’m willing to negotiate price if reasonable. Please don’t waste your time or mine with a low ball offer. I’m selling vehicle AS IS NO WARRANTIES. Thank you!
All upgrades/ work done were done to improve the vehicle and as preventative maintenance. I have Receipts for everything that was put on the truck.
Lift Front- Bilstein 6112
Lift Rear – Bilstein 5100 paired with Rear Old Man Emu 2906 Medium Load Springs
Spc Upper control arms
White Line lower control arm bushing replacement.
Steering rack bushings replaced with energy suspension
All rear control arm bushings replaced with white line bushings
New OEM Toyota lower ball Joints.
New OEM outer tie rod ends.
New Denso Radiator
New Toyota Red Coolant
New Ko2 tires 265 75 16 less than 1000 miles on them.
New Brembo front brake rotors.
New Akebono front brake pads.
New Rear drums and brakes replaced.
New front and rear stainless steel brake lines.
New Ngk Spark plug wires
New OEM spark plugs (denso I believe, bought at dealer)
New OEM –Timing belt/ Water Pump service done
New OEM Belts
New OEM Fuel Filter
New PCV Valve
Started LED interior light conversion
No rust on frame
No rear locker
Cons-
Cv axles are leaking due to lift. Cvs May need to be changed.
Antenna stopped going up and down recently.
Needs Alignment
Paint on roof is burned by the sun
Bumpers have a few dents- a non-issue if you’re looking to armor your vehicle
00' Toyota 4runner Limited 4x4-Adventure/Camping Rig
17' Toyota Camry XSE- DD
98' Toyota Corolla- SOLD
87' Toyota Tercel- SOLD
