Originally Posted by rpete
Yeah man let's just say I wasn't excited when I pulled the radio out. Thanks for your response.
Yes it is still the original OEM radio.
I couldn't see any original speaker wires still in there. And I know if they are they don't still run to the doors. The guy routed the new wiring bad too so initially when you would role the windows up or down it would also catch the wires.
I do not have the JBL system. Just the basic plane Jane system.
In regards to the blue wire under the cup holders: Next time I have it apart I'll try to trace it back a little better and see if I can find where it is going. Make sense though, I couldn't figure out why they'd want to get power from all the way back there. But ignition power makes sense. However there are no aftermarket lights on it except for a light bar which I installed, Pretty sure there isn't an amplifier, and honestly I got it and it was completely stock except for obviously the speaker wire for some reason. There isn't anything weird to it that I know about that would need that power.
Gotcha. So I think there was definitely an amplifier installed somewhere. Is there new speaker wire for all 4 speakers or just 2?
Another thing to find out will be does the new speaker wire go straight from behind the radio to the speakers or does it go somewhere else first?
The reason I am asking is because there may be a “junction” somewhere. It will be where ever the amplifier used to be and there could be some bad connections there as well.
