Originally Posted by evan1242
So yeah the normal stuff for the front.
Trimmed off that tiny little lip that pokes out towards the tire. Then heated up the inner fender with a heat gun and pushed it in rather than cutting it all to bits.
-17 will only be .197 of an inch more than I’m at currently. I don’t think it will be to far out but don’t expect to be able to keep it clean for long periods of time. Lol.
I'll keep this is mind as I'm doing tires real soon. I'm actually thinking of going with 295/70s since they're only .6" taller and .1" wider (.7" taller and ".3 wider than your KO2s) than the same brand 285/70s.
How much body mount clearance do you have with +3 degrees caster? It's strange that
_kbarb
had rubbing issues on the body mount with +4.3 caster and roughly the same size tire...
