Originally Posted by Ed_C
Are you sure you tapped into the correct wiring? Voltage should vary from 0 to 12-13v at the turn signal circuit when it flashes, not constant voltage.
The flasher relay is under the dash, did you leave the windows/sunroof open last night?
Didnt leave the windows open.
I may have touched the fog light pos/neg wires together but i dont see how that could mess up the blinkers. Fogs still work.
Im sure i cut the correct wiring because the turn signals still plug in. I checked the voltage again and its going from ~1.5 - 9 when i engage the blinker. Not sure what that means.
