Originally Posted by evan1242
Definitely an interesting one you have there.
Try taking the red wire loose from the radio harness and touch it to the yellow wire and see if it comes on.
Yellow is constant power
Red is switched power.
If it comes on then there is a problem with switched power.
So using the wiring diagram in my link below I’m testing the C and D spots with using G as my ground. C is ignition (switched?) and D is Battery. C shows 12V when the engine is running, D isn’t showing power regardless of if the engine is running or not. C is a light grey wire, D is blue with yellow stripe. The only yellow wire I found on the factory side of things seems to be a speaker wire? I’m not sure. It’s not on the main connection for the radio however, it’s a separate plug.
Imgur: The magic of the Internet
