T4R Group Pricing is already applied so no need for a discount code!
Never before has so much capability been packed into one direct fit suspension kit. BILSTEIN B8 8112 (ZoneControl CR) suspension kits incorporate a new, revolutionary technology, delivering position sensitive damping in both compression and rebound. ZoneControl CR provides unparalleled comfort during everyday driving conditions, combined with maximum control under large suspension inputs. BILSTEIN B8 8112 (ZoneControl CR) suspension kits will enhance your suspension performance to a level that will defy convention.
Features & Benefits:
- ZoneControl CR: Position sensitive damping with 3 compression zones and 2 rebound zones, controlled by 3 independent pistons
- Compression ( C ): Provides superior bottom out control through a 2-stage, telescoping internal compression stop. This feature eliminates the need for an external hydraulic bump stop
- Rebound ( R ): Secondary rebound stop will dissipate spring energy and stabilize the suspension directly following a large compression event. The internal rebound stop will also eliminate harsh top-out events and the need for an external limit strap
- Triple piston design delivers comfort during every day driving conditions and maximum control under large suspension inputs
- Adjustable threaded spring seat allows for fine-tuned ride height. Adjustable range .6-2.5in
- 60mm remote reservoir for increased oil capacity and cooling
- Vehicle specific design and tuning provides the ultimate driving experience. Aerospace quality components are vehicle specific to optimize wheel travel and clearance
- High quality chrome 5/8” heim joint mounting with rubber sealed misalignment spacers offer the most durable, load bearing mount solution
- Aluminum components with zinc plated shock bodies will resist harsh off-road elements
- Coilover supplied as a complete module for easy installation. Spring is pre-loaded to the factory recommended ride height
- Factory rebuildable
- Made in the USA
ORDER BELOW
41-284568 - B8 8112 (ZONECONTROL CR) - FRONT LEFT CORNER MODULE
41-284575 - B8 8112 (ZONECONTROL CR) - FRONT RIGHT CORNER MODULE
41-284865 - B8 8112 (ZONECONTROL CR) - FRONT LEFT CORNER MODULE (HEAVY LOAD)
41-284872 - B8 8112 (ZONECONTROL CR) - FRONT RIGHT CORNER MODULE (HEAVY LOAD)
BILSTEIN B8 8100 (Bypass) is a direct fit, position sensitive, damper for light trucks and SUVs. These motorsports inspired shock absorbers utilize a dual tube externally adjustable bypass design. B8 8100 (Bypass) feature Incremental Flow bypass adjusters, allowing for finite and incremental changes for rebound and compression. The shocks utilize a bottom hose, remote reservoir exit port, delivering increased compression control during the full cycle. The remote reservoir is supplied with a bolt-on aluminum anodized chassis mount for an easy fitment. BILSTEIN B8 8100 (Bypass) will maximize the driver experience, offering unparalleled ride comfort and incredible bottom out control.
Bypass shock absorbers offer the most compliant ride in all conditions and provide maximum bottom out control when the road gets rough. Utilizing an adjustable external bypass shock is the easiest and most effective way to tune your suspension for ultimate performance.
Features and Benefits
- The Bump Zone, located above the compression bypass tube, increases bottoming control and eliminates the need for a hydraulic bump stop
- Dual tube external bypass offers position sensitive damping with independent adjustment for rebound and compression
- Incremental flow adjuster offers finite and incremental changes in damping force for precise adjustments
- Vehicle specific tuning with the ability to make a wide range of adjustments
- 60mm large bore hard anodized aluminum piston offers a greater range of damping control and delivers exceptional long-term durability
- Bottom port reservoir hose provides increased bottom out control during the compression cycle
- 60mm remote reservoir with machined aluminum chassis mounts
- 18mm piston rod provides brute tensile strength and reduces internal gas force ramp-up providing a smoother ride
- Billet rod end with vulcanized mounts for an exact OE fit and long-term durability
- Direct fit for easy installation
- Owner rebuildable
- Made in USA!
ORDER BELOW
25-284584 - B8 8100 (BYPASS) - SHOCK ABSORBER REAR LEFT
25-284591 - B8 8100 (BYPASS) - SHOCK ABSORBER REAR RIGHT
Questions? Quotes? Click here to PM us - lets talk Bilstein!
BATTLE BORN OFFROAD
FACEBOOK | INSTAGRAM | EMAIL
