Originally Posted by anormalflame
The passenger rear axle seal is definitely leaking. The driver side is clean as a whistle. Can I get away with just swapping the passenger side?
You should be able to, it likely started leaking because your rear diff breather is plugged so make sure you fix that while you're at it. I just did the passenger side when I did mine as well as extend the rear breather
