I would answer:
#1. What is placing you in more danger of having an accident or failure - tires or UCA? Both are 'mission critical' parts so I would prioritize safety.
More questions:
- Are your upper ball joints in need of replacement? if yes -> UCA as a failed UCA can lead to an accident that totals your vehicle.
- Can you set an alignment with your current set up and UCA? if yes -> Tires, if no -> UCA because you will wear your new tires out and need to replacement them
- How long until you can buy the other item, aka, if you buy tires when could you buy UCAs?
2008 Nautical Blue GX470
Bilstein 6112/5160
