[QUOTE=VernySanders;3457649]
Originally Posted by UnderFire
Mine looked that way, I tried putting a chain inside of it on the end of a drill connected by wire that ran through pvc to prevent kinking. Didnt work out so well for me but a smaller version of what I did would work pretty well. Your rear control arm mounts could be pretty toasty. I drilled a hole at the front of the control arms in the lowest spot for drainage. I hit the frame with a 5 lb deadblow hammer and knocked out at least 10 lbs of rust flakes from the entire frame. Natural weight reduction, I didn't get afraid though because of the fact that if you look at any of the rot its all on the bottom on your frame just like mine. This summer i was going to cut the bottom of the frame out and give it a 20 year service, then seal her back up. With fresh steel.
Like you said, anything is fixable.
Past the kink up in the frame is all solid luckily. Just the silt that found its way in the end and kept absorbing moisture caused that. I'm glad it's not terrible and I'm planning on addressing it as best I can.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (
Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (
Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
